Me_Again
Jun 26, 2017Explorer III
I believe you will be over your rear tire/axle rating. I base this on towing a 16K 5th wheel with a SRW 3500, that starts with 200 less pin weight. If you what a slider hitch you will be over weight. If you get an Aluminum Andersen you might just make it. However you take a chance of hitting the cab/rear window with the trailer like others have. Chris
