john_b1
Dec 17, 2013Explorer
enblethen wrote:
5 amp fuse should be the 120 volt element.
Remove the cover of the circuit board in the outside access. Locate the two wires that go to the 120 element. They should be marked on circuit board. Us an ohm meter and check these wires one at a time to a good ground. Any measurement would indicate a grounded element. Normally happens where the wires enter the element in the stack.
Yours may look like this.
Dinosaur Board
Next would be to disconnect 120 volt power from refer, Remove the circuit board and look at the back for burnt spot.
Be sure to unplug from a/c current before trying this. Jb
44,030 PostsLatest Activity: Feb 04, 2025
