- RaftenExplorerIf it is a Dometic, did you change the switches at the top of the freezer door?
- PhotomikeExplorer IIIYou never had one and forgot while it was in storage.
- WheelholderExplorerI wonder why a question like this even gets a response? Do you guys think the op has checked the bulb?
Makes one wonder how some people get from point A to point B. - 2oldmanExplorer IIYour light switch has gone into SFR, or, Sudden Functionality Reversal. Have you changed out your batteries recently? That can cause it.
That means the light is now on when the door is closed, and off when you open it. You can verify this by drilling a hole in the refer door and having a peek inside. - Buzzcut1Nomad II
Bubtoofat wrote:
Your flux capacitor is running low and went into default mode.
you sure? sounds more like a di-lithium crystal issue to me - BubtoofatExplorerYour flux capacitor is running low and went into default mode.
- 2oldmanExplorer IISo many smart answers...so little time
- dakonthemountaiExplorerYou guys are all cards.... and need to be dealt with! ;)
Dak - billtexExplorer IIYou need a dually...
Edit; I see you have a dually...time for a med duty chassis - spacedoutbobExplorerIt could be a sticky door switch, like what happened on my Dometic Refrigerator.
Bob in Calif.
44,056 PostsLatest Activity: Nov 19, 2013
