sllims's avatar
sllims
Refrigerator Operation
O.K. another newbie question. I have dometic ref/freezer in my new TT. Can't seem to get it to work?? Does the gas & pilot need to be on and lit even when using elec? The longest I have been able to test with elec was 24hrs and no cooling at all. The gas bottles were off at the time. I got no instructions with the TT so just having to wing it. Any basic help would be appreciaated.
  • Well that's how new I am. I filled out profile but it's not showing up ???
    In any case the TT is a 2013 purchased new in Sept from dealer. I just buoght as second owner last month so it's only about 6mo old.
    I red up on the model and it says the temp settings are preset a factory. So there are no adjustments I can make. the only thing I see is a little plastic slider on one of the fins in the back. I have set the buttons to run on Auto but after a couple hrs the check light comes on.
  • Are you plugged into shore power?
    Post the Brand and model # of you frig. and you will get lots of help.
  • There's nothing in your profile so I don't know if 'new' is new or used.
    No, gas does not need to be on to run elec. 24hrs should show cooling in the freezer.
