Oreonut's avatar
Oreonut
Refrigerator Question
So we just purchased a Wildwood that has a 12 volt fridge previously we only had gas/electric small one.
My question is the book says don't travel with food in it. Really?? This can't be what everyone does.
How do you travel with the fridge running without the risk of draining the truck battery at meal stops? We do have a small solar system that came with the trailer but that is all new to us too.
Thanks for any info! Been watching some videos but now I just more confused than before as to what is the best way to do it. Our trailer will be unplugged the entire night before we leave an I'm afraid to put any food in it!
  • Lol, waiting for the “LP absorption fridges are stupid” crowd to show up and share their “wisdom”.
    Although you’ll probably get advice like if you buy a Rivian or Lightning to pull it, or install some LiFePO4 and SiO2 batteries and 10,000w of solar and a dc dc charger you’ll be just fine and that’s soooo much better and simpler than a bottle of propane! Hahaha
  • With the refer off and cold test to see if it's still cold in 2 hours, many will be. Overnight maybe to long. If the truck charge line doesn't disconnect with the engine off then add a relay. Now you know your needs.
    The best answer is to measure the RV drain (which may include more that the refer) to determine a course of action. More batteries is likely the best solution since solar doesn't work at night. Also guessing you have a small solar setup that is mainly for storage to maintain the battery.
    Guessing you have a single 12V car or marine battery, hence about 90 AH. 2 GCs would provide about 220 AH. Additional batteries can be in the truck bed.
  • I imagine the book is saying to not travel with food in it because it could drain the battery and thaw out and spoil the food.
    If you only have a single battery on the trailer I would travel with it on. But if I'm going to be at a rest stop for more than an hour I would probably unplug or turn it off to save the battery state of charge. The catch is you have to remember to turn it back on before you get back on the road or you're in paragraph 1 again with possibility of spoiled food.
    The small solar panel on the trailer really only slowly tops up the battery in storage. I wouldn't count on it being any use with the refrigerator.
