Tatonka's avatar
Tatonka
Remote control trailer movers
Does anyone have any experience with the near wheel mounted electric trailer movers / caravan movers ?
(Not the hitch dolly type but the type mounted in front and behind the trailer wheels.)
They look like they'd be quite useful in tight spots.
So far I've found these brands and I think there may be others...
Easi-mover
http://www.easi-move.com/
Dometic powrtouch
http://www.waeco.com.au/products5.asp?catId=160
Enduro
http://www.purpleline.co.uk/products.php
  • It would be pretty nice , UNTIL my 7 year old son found the remote and wanted to play with the camper because its fun. I can picture my trailer going down the street with 2 boys fighting for the remote .
  • Never of heard of it until now, look pretty cool though.
    With my luck, mine would short circuit and I would be running after my RV down the road.
  • They do sound very capable...
    "The Powrtouch All Wheel Drive Twin axle caravan mover drives all four wheels of the caravan. This allows for it to be used on a steep slope, turning uphill or on uneven ground (where the drive wheels may lift off the ground). This model will fit the majority of all twin axle caravans. The All Wheel Drive unit is comprised of two Powrtouch units which are positioned both in front and behind the caravan wheels and which are wired to work simultaneously."
  • BurbMan wrote:
    Very cool, but if I had $2300 to blow it sure wouldn't be on this. I'll bet that system would move a TT up on leveling blocks; the factory tongue jack would be fine for paved areas but I'll bet those casters would get jammed up on a lawn or unpaved area. Those 4 powerful motors must eat the juice though....I wonder how far you could maneuver a TT with 2 12v batteries onboard? And I'll bet the setup adds a lot of weight to the TT also.
    I would think you would be better off with a quality set of towing mirrors...with this remote setup, you would constantly be walking back and forth to see both sides of the TT while you are backing. With good mirrors, you can see both sides from the driver's seat and back the TT more efficiently.
    Tatonka is there a specific need for where you park your TT that you are considering these?
    Yeah the casters look like they'd be useless on lawn or gravel... But that's a easy fix, a larger wheel or tandem casters.
    A few years ago i stupidly got in a tight spot where the way out was blocked and my wife and I were totally alone had to back our trailer out around several curves with inches of clearance between a wall and a sharp drop off, which took several hours.
    One other time I had great difficulty backing the unit into a smaller site and thought at the time that these things would have made it a snap... And would allow us to regularly choose smaller rustic sites.
    A generator is higher on my list, but when the batteries die we do just fine without power so I "really" don't need to spend any more money. ( When my wife and I tented around Alaska we took two tents, a larger tent and a $12 pup tent for quick setup in the rain but ended up using the pup tent numerous times. That's when I realized that anything beyond that is just an unnecessary luxury.)
  • JJBIRISH wrote:
    They would be great if you have money to burn for something you don’t need and would rarely use…
    I know... it's like air conditioning. A total waste. If you have windows and some shade why on earth would anyone blow their money on a/c... Most trailers didn't even have it years ago. ;-)
    Still, our trailer is loaded with burnt money options ( TV, a/c, oven, microwave...). Camping is all about campfires it seems.
  • Very cool, but if I had $2300 to blow it sure wouldn't be on this. I'll bet that system would move a TT up on leveling blocks; the factory tongue jack would be fine for paved areas but I'll bet those casters would get jammed up on a lawn or unpaved area. Those 4 powerful motors must eat the juice though....I wonder how far you could maneuver a TT with 2 12v batteries onboard? And I'll bet the setup adds a lot of weight to the TT also.
  • Wow thats cool, but so unneeded. I also dont think they would be powerful enough to drive onto leveling blocks.
  • They would be great if you have money to burn for something you don’t need and would rarely use…
  • After watching the videos of the trailers being moved around, I think the front jack mount would need to be much stronger than what is found on most trailers from the factory.
    Fred.
    Easi-mover
    Clicky 1
    Dometic powrtouch
    Clicky 2
    Enduro
    clicky 3
    I have not used one myself. Made them a clicky, so others can see he website easy.
    Fred.
