work2much
Jun 29, 2017Explorer
Yes, unscrew and pry it off. If there isn't any way to detach the wires cut them. Fill all the holes with dicor sealant or eternabond tape. Either should work if installed well.
If you don't use the radio antenna no reason to worry about it. Unlikely someone will devalue the camper later for not having a working radio antenna.
Should be a pretty easy job.
44,026 PostsLatest Activity: Mar 03, 2025
