Walaby
Sep 17, 2015Explorer II
I did a lot of research, ST vs LT, both here and off the forum. In the end, I decided to go the LT route. Yes, there are emotional fans of both types of tires.. some will never convert, some will tell you if you go 66MPH with an ST tire for 30 secs, you're tires will explode because you've "abused them" for 30 secs.. (Okay exaggeration for effect).
I had a set of the China Bombs on my TT when I purchased it. I decided I was replacing them, and in the end, decided to go the LT route. I would simply suggest you do your own research, take everything else everyone says (including myself), with a grain of salt. Look at things with an open mind and make an informed decision.
Mike
Mike
