Well at the shop, we have found it to be cheaper to replace the entire window-frame and all-than to try to replace just 1 pane.
--Problem is, you must take pictures of the frame, measurements, any radius, and a picture of all the little stickers/numbers/info on the corners of the panes. It takes several weeks for Hehr to send windows, and usually they are wrong, but when you finally get the right ones, they replace very easy.
Like I said. It has proven to be (A considerable amount cheaper) to replace the entire frame/windows/unit.
Usually an RV dealer can get this ordered for you. However as someone mentioned, if you carry "comprehensive" insurance on your camper, then call insurance and let them handle is as they will.
