afidel wrote:
goducks10 wrote:
haste maker wrote:
I am sure many will say I am full of **** but the best thing you can do is what I did when I had a TT...which is remove the "China Bombs" which are on all new TT and replace them with Light Pick-up Truck tires...
What LT tires do they make in 14"?
There are a few for VW vans that are 14" and in the correct width and load rating for travel trailers.
But the fact remains, in 14”&15” sizes, you can get significantly higher load capacity in comparable ST tires than the few unicorn LT tires that are still on the market.
OP, only 2 years old, and yes you have notably cheap tires. I’d consider a few things before scrapping them for new.
1. Are you going to use the trailer much or at all this winter? No point in new tires just sitting for 6mo or however long.
2. Are you relatively sure the failure was a defective tire? IE: Not a blow out from a road hazard or low tire pressure (for whatever reason).
GY Endurance are now considered the new “best “ trailer tire for a couple years running now.
For consideration, I have 2 sets of Kenda Karrier tires on our boat trailer and sled trailer. They’ve been good tires for 5&7 years respectively now. Are they too old? Maybe….likely.
But they’ve held up well and I’ll buy them again.
