APT
May 29, 2018Explorer
Since you are used to the diesel - get a newer one. Any of the 2011+ HD gas trucks will tow your TT with the 4.xx axle ratio. The 6-spd transmissions really help keep the engines in their powerband, but that will be much higher than you are used to. Expect a lot of time in the 3000-4000rpm range. Again, a 2011+ diesel will tow great. Lots of power, better gearing, etc.
Since you are planning a 5th wheel, get the dually. SRW diesel crew cab has about 3500 pounds of payload. Dually is closer to 5000.
You said you do not pack light.
44,029 PostsLatest Activity: Jan 28, 2025
