Caryite
Oct 11, 2018Explorer
donn0128 wrote:
Replace all 4. Take the best of the newest as a spare. You had a blow out on a tire a year beyond reasonable life expentency. Trailer tires regardless of brand are only good for 5 years. After that your playing with a loaded gun.
Thanks all for the replies. I should have mentioned that I opted to buy a new Power King Tow (Blow) Max to get home in the same tire size and 50 PSI, because I didn't want to run on my older original bias ply spare for over 200 miles. I plan to use that tire for my spare going forward and have that one moved when I get the 2 new tires for my front axle.
I don't think I will go with a different tire using a different PSI, even if on a different axle.
I would be fine with two more LR C Maxxis and replace all 4 after another 4 years. By then, we'll see which tire(s) are the most recommended.
44,067 PostsLatest Activity: Jun 05, 2026
