mobilefleet's avatar
mobilefleet
replacing a duo therm brisk a/c unit- need help
bought a camper from an auction that needed some repairs. The main repair is the ac unit got clipped by a tree and the top portion needs replaced. it's a duo therm brisk model 59516.331 which appears to be 15k btu. The control unit inside is fine. My question is, do I have to replace it with exact same model or will any dometic 15k unit with the same white 6 prong plug that plugs into side of control unit work if i just plug it up and go? hoping to find a salvaged top unit
  • I know which connector your talking about!
    Unfortunately I don't know it the 15K uses the same one but I can't imagine why it wouldn't since the bottom parts and the stat are the same.
  • IF you need to change the whole unit they will all interchange as they fit into the 14" square hole.
    Now if you only need the outside cover those are available in direct replacements and more rugged units just google your brand and AC shroud.
  • I'm confused, do you just need a shroud or something more ??
