- fj12ryderExplorer III
specta wrote:
Pull the cover off the master cylinder reservoir, now compare that brake fluid to new fluid. The reason it's a different color and murky is due to contamination.
"IF" it gets contaminated.
That's something that I have personally never experienced.
While working in the automotive field the only time I saw brake fluid that was contaminated was when someone added something to the master cylinder other than what was recommended by the manufacture.
I'm not saying don't flush it, I just don't see it as a problem if you don't. - spectaExplorer
whjco wrote:
I had an Excursion and a 2000 Econoline E350. Both had issues with the inner lining of the flex hoses sluffing off and causing a restriction in the hose that kept the calipers from fully retracting. I'd recommend that they replace the flex hoses on that Excursion. Also, keep a close eye on flex section of the brake line that goes from the master cylinder to the antilock unit on the frame. I had to make a panic stop and the flex portion of the brake line blew out and I had a total loss of brakes. I had to cut quickly to miss the car that had stopped suddenly in front of me and then I ran through a red light. Thankfully the cross traffic saw that I was in trouble and waited for me to get through the intersection. I was pulling my 24' car trailer and was able to use the trailer brake to get stopped.
Those $450 pads were extremely hard.
They never had a problem after they replaced them with a different pad made of different material. - Years ago I was told by the dealer the Motocraft are not exactly the same as the original pads. Had to special order the originals and they definitely lasted longer. Don't recall a big difference in braking power so must have been close on that regard.
- Dave_H_MExplorer IIUUUUHHH whico, I said I bought the Motorcraft pads at ford and changed them mysef. They work like new and have no pig noises in them.
- whjcoExplorer
specta wrote:
Dave H M wrote:
I just changed the front pads on the F250. Bellied right up to the Ford parts counter with a fat wallet.
Only complaint is that they did not provide a decal for that money. :B
A few years ago my daughter's husband had new brakes put on their Excursion, he told them he wanted the best pads they had - $450 for just the front pads. Two new Ford rotors plus labor on top of the $450.
They squealed like a pig all the time so they took it to an independent after several trips back to the dealer and had less expensive pads installed, squeal gone.
I had an Excursion and a 2000 Econoline E350. Both had issues with the inner lining of the flex hoses sluffing off and causing a restriction in the hose that kept the calipers from fully retracting. I'd recommend that they replace the flex hoses on that Excursion. Also, keep a close eye on flex section of the brake line that goes from the master cylinder to the antilock unit on the frame. I had to make a panic stop and the flex portion of the brake line blew out and I had a total loss of brakes. I had to cut quickly to miss the car that had stopped suddenly in front of me and then I ran through a red light. Thankfully the cross traffic saw that I was in trouble and waited for me to get through the intersection. I was pulling my 24' car trailer and was able to use the trailer brake to get stopped. dodge guy wrote:
specta wrote:
BobsYourUncle wrote:
14 1/2 years and 412,924K on the odometer and it's never been changed.
Kind of makes you wonder just how important it is to flush it.
Very important! Bobs a great guy, but I would not recommend not doing it if you are doing brakes. As long as the bleeders aren’t frozen it’s an extra 15 minute job.
I just flushed the fluid on my 12 Motor home. Has 40k on it.
An engine fails you stop moving, a trans fails you stop moving. Brakes fail you can’t stop moving fast enough!!!!!
A great guy? Shucks, thanks! :B
But Dodge Guy is right on with this one.
I am at fault for not flushing my brake fluid. It IS important! I know I should have done it years ago, but somehow never got the job done.
Some of it has been changed though with a few brake jobs and I think at least one set of calipers.
Gotta wonder what the inside of the master cylinder looks like....:h
Yeah, I really need to get that done. Temperature swings here from minus 30s to plus 30s C.- spectaExplorer"IF" it gets contaminated.
I'm not saying don't flush it, I just don't see it as a problem if you don't. - dodge_guyExplorer II
An engine fails you stop moving, a trans fails you stop moving. Brakes fail you can’t stop moving fast enough!!!!! specta wrote:
Brake fluid with moisture contamination can work fine... until it doesn't.BobsYourUncle wrote:
Same for coolant hoses, belts, battery, fuel filter, etc.- spectaExplorer
44,066 PostsLatest Activity: Oct 04, 2013
