d3500ram
Dec 31, 2020Explorer III
Seminoe Joe wrote:
1) caulking needs to be checked and replaced FREQUENTLY in hostile climates like southeast Texas. ...
So true. Inspection and maintenance is key to keeping a camper in good condition.
Seminoe Joe wrote:
2) spray on “Flex Seal” is ok for emergency repairs, but after just a couple of months becomes brittle, cracks, and peels off. It’s useless for long term!...
I cannot disagree.
Seminoe Joe wrote:
3) using butyl tape AND lap sealant AND eternabond is the way to go!...
Yep. As well as removing old and installing new properly the first time. Had to redo a fix when I did not install Eterna Bond the first time. Toup to remove where it adhered. But finally did the job correctly with a new bubble skylight:
Before:
After:
Seminoe Joe wrote:
For the ceiling I’m currently eyeballing this: CLICKY
Seems like it might be better for a shower where humidity and moisture are a constant potentl threat to simple luan.
I would not use luan.
If you use FRP, consider cutting it on a table saw with correct blade to minimize a rough edge... you'll want a smooth as possible edge to install a clean caulk bead.
