Fisherman
Dec 31, 2020Explorer
Seminoe Joe wrote:
Thanks. I’ll look into that FRP. I finally got the leak under control. Took lots of experimenting and I learned the following that may be of use for others:
1) caulking needs to be checked and replaced FREQUENTLY in hostile climates like southeast Texas.
2) spray on “Flex Seal” is ok for emergency repairs, but after just a couple of months becomes brittle, cracks, and peels off. It’s useless for long term!
3) using butyl tape AND lap sealant AND eternabond is the way to go!
For the ceiling I’m currently eyeballing this: https://www.homedepot.com/p/Glasliner-4-ft-x-8-ft-White-090-FRP-Wall-Board-MFTF12IXA480009600/100389836?source=shoppingads&locale=en-US&mtc=Shopping-B-F_D30-G-D30-30_27_PANELING-Generic-NA-Feed-LIA-NA-NA-&cm_mmc=Shopping-B-F_D30-G-D30-30_27_PANELING-Generic-NA-Feed-LIA-NA-NA--71700000052659303-58700005045840622-92700044042640858&gclsrc=aw.ds&&
gclid=EAIaIQobChMI2rDBwoT57QIVUPDACh1k9wkxEAQYBCABEgLsRvD_BwE
Seems like it might be better for a shower where humidity and moisture are a constant potentl threat to simple luan.
That fibreglass sheet will work quite well. I used it for an exterior window cover on the front of my old T/T a few years ago, held up for at 4 years before I sold the trailer. Just use a dust mask and gloves when cutting. I used masking tape on both sides of the sheet where the cut lines were to minimise any splintering and had a fine cut jig saw blade.
