IAMICHABOD
Nov 10, 2014Explorer III
I had the same problem. Let me ask, did the pin on the end of the door break? if it was the one that is spring loaded I just got a small bolt that would fit,and cut to length then put it in the the hole and used a spring from a pen to replace it.
That worked until I could find a replacement. I them went on EBAY and looked until I found a replacement.
I found a door that would fit by using the part type and # plus the size but found that just the door was more expensive than a whole unit so I bid on the whole unit and got the whole thing cheaper and just used the door,now I have a replacement if I need one, and I may need it because the fitting on the original is leaking now.........
44,068 PostsLatest Activity: Jun 21, 2026
