westend
Jun 25, 2014Explorer
fla-gypsy wrote:Yeah, brass should be better than the cheap plastic stuff, right? The issue is not so much with thread size but the casting of the brass. Starting about 15 years ago, I was having problems with sink hardware. I've since found it is about the quality of the brass in the casting process. Anything cast in India or China is treated like glass when I handle it. Not your fault, it is the times.
It is threaded but be careful that you have an exact size replacement for it. I had the same thing happened and attempted to thread a brass fitting into mine and all seemed well at first but later the port split wide open. I may have over tightened it but I am not sure.
