silverbullet555
Oct 07, 2020Explorer
I've read that regulators go bad over time and should be relaced. Is that true?
At some point, I am guessing the regulator was hard plumbed in to the outlet and then whoever changed it went to this set up which isn't ideal.
Solving for the regulator first solves the rest. Plumb it into the main line and then run a rubber line with a BBQ type screw on connector?
Is there a definite pressure that RVs are supposed to use?
