Leichardti's avatar
Leichardti
Explorer III
Jul 01, 2016
Replacing tornado tank sprayer. Best adhesive/loctite?
Replacing the camco tornado tank sprayer that has developed a crack.
Using the same screw holes to mount the new sprayer.
Do you guys think I should use some adhesive or loctite like material to help secure the sprayer to the tank?
Maybe something on the thread of the screws?
I will silicon around the edge of the sprayer but maybe used plastic expoy as well?
Thank you for your time.
  • Do you envision replacing it again? If so, RTV silicone and a paper gasket. On forever--RTV silicone. You could use any kind of sealant, Goop or Shoe Goo also being good ones. If the housing for the sprayer and the tank are both ABS, the solvent weld ABS adhesive would make it one.
  • I would use Shoe Goo sticks to ever thing even fingers.
    Ken
