SybrinaExplorerMay 30, 2022Reverse polarityI hooked up my battery backwards on my 1994 skyline Layton and now my slider won't extend. What is the problem and where can I find it?
LScamperExplorerMay 31, 2022So the slide works with the battery alone with nothing coming from the converter? That would be the same as the reverse polarity fuses being removed. The fuses are not needed to use the slide! So bad fuses will not stop slide from working.
Related ContentReverse polarityGenerator/ Reverse Polarity QuestionReversed Polarity Issues?Polarity reversed?Reverse Polarity of Batteries
