camperforlife
Nov 23, 2013Explorer
DanB-ON wrote:
You need to find out what your local dealers are using and how well they are preparing and spraying the trucks. Coming to forums like these is a great way to gain information but it could mislead you somewhat as you could go to somewhere based on someone's experience and your local dealer is using a completely different product.
Rhino has lots of different products, and some dealers are still using the older style spray equipment (the thick and softer liner referenced several times in this thread) while many have moved onto the new 1 to 1 ratio hot machines that are more or less the same as Line-x.
Although Line-x doesn't have as many products as Rhino, they do have several products in their line up as well, so again finding out what your local dealer is using is key.
Dan, I get the impression that you are very happy with your local dealer and have confidence in their opinion. I have a great GMC dealer and respect what they say as well. Unfortunately there are a lot of dealers out there that use what ever liner supplier that will give them the best cut allowing them a bigger profit margin. Opinions on the forums certainly aren't perfect but at least profit isn't affecting the opinions.
Dan: On edit I see you may be referring to what different products the local liner dealer might be using and yes it could very well change your purchase decision.
