path1 wrote:
Colo Native wrote:
Just wondering what others have done.
What I did...
One fitting for each side. Reason, so air can't bleed one to another when cornering.
Each air line terminates where I can fill with small compressor, right from cab. Under my running board side step, by drivers door.
Get a "tube cutter" to cut air lines. My pocket knife made rough cuts and I had a couple small air leaks. Nice clean cuts at 90 degrees will save hassles of messing with small air leaks later.
I put vinyl tubing around air line if there was any chance of it rubbing on metal.
I know some people have air pumps, air tanks and gauges in their trucks. They can push a button left or right and pump starts and gives psi level and all. But for me, airing up with bicycle pump is the way to go. Mine are only 1/4 inch airline so there is not much air volume needed anyways. About 8 or 10 strokes does me fine. Maybe 14 or 16 if real heavy load in pick up bed.
I don't air up to a certain psi. I air up till I'm level. I sometimes have load in pick up (fire wood or whatever) so filling to a certain psi didn't make me level. I just put a level on rail of pick up and pump till level.
http://www.amazon.com/Ridgid-23488-Scissor-Style-Plastic-Tubing/dp/B0019MLSLS
I didn't think of this at the time, but I saw a guy that mounted his air valve pretty slick. He picked up an old eye glasses case from junk store for couple bucks. He mounted his air valves inside the eye case and that was mounted where the gas cap is. Pretty good IMO. Easy to reach and out of the weather.
Mounted in the rear license plate holes, and with a valve cap on them, is about as good as gets, and that keeps the weather off them.
I have installed airbags in three trucks, and a good razor knife cuts those air lines square ,and clean, with no leaks. Just saying its a tool most have without having to go out ,and buy something. Yes I do know they have to a pretty clean cut, found that out not cutting them with a sharp enough tool .
