spoon059 wrote:
I used a Tee fitting. If you are going so fast that you have to worry about air dumping from one side to the other while turning, you shouldn't be towing or hauling. I got tired of trying to adjust the bags perfectly right, and if you have a WDH and unequal pressure in your bags you can put more strain on one WDH bar than the other.
I never had a problem with the Tee fitting. If I have a load in the bed or am hauling the trailer, I'm not taking turns fast enough to worry about the possibility of body roll.
It's not just in turns. Just a light wiggle of the steering wheel running straight down the road shifts a lot of weight when you are loaded. When running the bags together the pressures will always equalize. The small air springs you guys are using fluctuate greatly in pressures with the slightest little compression. When one side loads up more than the other it will lift the other side when running them together. When running them separately one side loads up the spring will gain pressure holding the load up better and the other side will hold the same or loose pressure not lifting up on the lighter side as much.
