Huntindog
Jul 30, 2013Explorer
uzikaduzi wrote:
i don't understand how 2 bars could cause a binding issue... it seems that the forces being applied with 1 regardless of which side you choose to use it on, would be the same type of forces on the other... unless there was a bit of play between the ball and the tongue which is scary to think about whether there is or is not any sway control.
i've never used the friction bar type sway control. i may be incorrect on this but it seems like a better idea to have the trailer want to right itself like a dual cam then to resist all movement.
The DC is a 100% friction based control. Not sure what you are trying to say, but the DC does not force the TT back into line. It has friction in both directions, but less friction when moving back to center... This may or may not be desirable depending on circumstances and point of view.
