camperforlife
Jul 30, 2013Explorer
jerem0621 wrote:
Sorry, Etrailer is FLAT wrong on this one. Every set of instructions I have seen for any friction sway control state that two bars may be needed for trailers over 24-26 ft in length.
I will trust manufacturers instruction over a salesmen on the telephone any day. Why? Because its still about the sale. If you still experience Wiggle with your trailer you will be more likely to spend several hundred dollars on a fancy integrated sway control WD hitch...because obviously friction sway control doesn't work..
I run two... have for years.. have for thousands of miles... several on this forum and thousands on the road have as well. There is nothing unsafe about running two bars.
I ran one sway bar for a while and still had some "wiggle" (not sway) between the TV and the TT. Added the second bar and the "wiggle" is gone. I am at 31 ft and 7000 ish lbs.
And Here is a left hand sway control if you really want a specific left hand model.
However, any sway bar can be used on either side, its simply a matter of flipping the slider bar and swapping the on/off handle and the tension screw.
I have Dual-Cam, it grenaded a WD hitch, took that off and put my reliable friction bars back on...
Anyway, folks will discount the friction bars and thats fine. They just reliably work. YMMV.. but I can testify from first hand experience that there is no myth to the effectiveness of a properly loaded TT, a properly loaded TV, a properly set up WD hitch, and dual friction sway control.
Use one, if you still have some wiggle, add a second. It may suprise you.
Thanks!
Jeremiah
This is the best and most accurate answer and is backed up by the Etrailer site, Reese site and the Husky site.
I have a 2500HD truck and a 6500lb 28' trailer and ran 1 friction sway. Truck and trailer handled great with no sway but I did get push with trucks passing. I added the second friction grip as all manufacturers of the product recommend and you can feel the difference. Almost all push is gone. If you have a 26'+ trailer and you have 1 friction grip, YES you will benefit from the second. If you can afford a more expensive setup, then yes that would probably be even better.
