LVJJJ
Dec 30, 2013Explorer
As I tow with a short wheel base 1965 Chevy Van, I used to use two anti-sway bars, til I replaced the chain on my WD hitch with a square steel tube, bolted the upper end to the A-frame, drilled right thru the snap-up mount, then a bolt thru the U-bolt on the bars. I tighten the upper bolt thru the A-frame real tight for a lot of friction, so it acts like the expensive Equal-I-zer,Reese etc. anti sway hitches. Sooo simple, fee and easy. I finally figured out that all the anti sway hitches do is either eliminate the chain and/or severley restrict it from moving too much and too easy using friction. For safety sake, I do use one of the anti-sway bars, lightly tightened. Now instead of those skittery back and forth movements and of course big swaying from wind or semi's, it's rock solid back there. Works so good I should probably patent it.
