marpel's avatar
marpel
Rim max PSI
Am in the process of replacing the tires on the trailer. Current tires (and the ones which came with trailer) are load range C and maximum psi is 50.
Have been looking at the new Goodyear Endurance, load range D and psi of 65.
In doing some research, I have come across a number of forum threads (on other sites) in which the discussion revolved around the rated psi of the rim. As usual, there are varying, and opposing, opinions.
It seems reasonable that, like tires, the psi rating of a rim is based on a "cold" temperature and the raise in psi (from use) is taken into account by the manufacturer.
However, other than the opinions of some, I can't find any actual documentation anywhere that would support this position. In fact, there is a thread in which a poster contacted a rim manufacturer who would not commit, one way or the other.
So, my question: Does anyone know of any bonafide documentation that states whether the max psi of a rim is for cold pressure or is the max pressure, period?
Thanks,
Marv
  • Unlike tires, wheels don't care if the inflation pressure is cold or hot. It only experiences pressure.
    And just to add to the confusion: The federal regulations do NOT require max pressure to be delineated on wheels (unlike tires!). There is a reason for that.
    I've contacted as many wheel manufacturers and wheel engineers as I could find, and not one of them said that pressure matters - that LOAD is what matters and that is regulated by the bolt hole configuration. In other words, the design the wheels based on what the vehicle engineer specifies for the bolt holes.
    So the Federal government hasn't regulated this area since everything is working fine.
  • You haven't indicated just what your current tires are but based on what little info you did provide I'd guess you're currently running ST205/75 R14 LR C tires. If upgrading to Goodyear Endurance tires they would be ST205/75 R14 LR D tires which are to be cold inflated up to 65 p.s.i. Some with lighter trailers would argue it's not necessary to inflate fully to this pressure but others, myself included, do run ours @ 65 p.s.i. regardless. Others may also disagree but with this size especially I wouldn't have any concern at all as to whether the stock rims that used to carry LR C / 50 p.s.i. tires can handle LR D / 65 p.s.i. tires ... your concern is much ado about nothing. JMO. :)
