Buzzcut1
Jul 10, 2014Nomad II
67 I use the airbags just to make sure the truck is level but I always make sure the stable loads are in firm contact with the over load leafs. For me 25psi is all that takes. My airbags are independently plumbed. The OEM bars were a bit soft and after 11 years pretty much worn out. Another factor in sway is the tires. Heavier duty tires with thicker sidewalls have less roll side to side which relates to less camper sway. I took a systems view and tried to upgrade all the factors in the suspension system. Tires, shocks, springs, airbags and sway bars.
44,066 PostsLatest Activity: Oct 04, 2013
