Hi, picked up our 2906 last Friday. We love the layout and have not found many issues so far. Haven't had any heavy rain to test for leaks. Our unit only has 1 13,500 AC unit which seem to be standard for southern NJ, not sure how well it will cool this unit on 90 degree days. We will find out soon enough.
One issue I'm having difficulty with is loading the trailer with 10 Gal. fresh water for traveling along with everything else and it appears I may not be able to keep the tongue weight below 15% of the GVWR. I have a 2000# scale and it is already at 1235# and everything is not in the trailer. I will move things around, but if I put much in the front storage compartment it will be difficult. I have a Reese straight line dual cam hitch with 1200# bars and don't want to go to 1700# bars and be over 15% of the GVWR. Suggest you check you tongue weight when loaded. Any suggestions or feed back will be appreciated.
