rk_texas's avatar
rk_texas
Rockwood Mini lite - tiolet pressure
The toilet pressure is way too high. When ever you flush it gets water everywhere, even with the lid closed. Is there a way to adjust the pressure or does something need replaced/adjusted?
Rockwood Mini Lite 21'
Toilet is made by Thetford, Model #31687, AM5 HI FOOT, 100726-31687-0155.
Thanks Guys
Glad I found this site.....will visit often. Lots of good hints here.
  • It is supposed to flow around the inside of the rim. But it hits it with such force that it flows over the rim, splashing water everywhere.
  • rk_texas wrote:
    No the fan is not running. Was hoping to find a adjustment for the toilet pressure.
    You could put a valve on the supply line to the toilet and then partially open it as desired.
    In my case I have this Dometic toilet (don't recall the model number) which has the outlet on the back of the rim of the toilet (dumba*s design) and which cause the water to shoot around the rim and sometimes up and over. I pushed down on the head of the outlet a little and the water jumping out seems to have stopped. Your description of the water going everywhere does not really full describe what is going on - more information on how would likely provide more precise answers. :)
  • No the fan is not running. Was hoping to find a adjustment for the toilet pressure.
  • Do you have a regulator on the city water hookup? This was an issue for me until I started using one. You can also partly shut the supply valve at the spicket, but the regulator should be part of your standard gear. Never use my pump so can't answer for that.
  • Actually I am having the same problem. I have a 2013 Gray Wolf 26BH that I just got early this spring. When ever we flush whether running the pump or hooked up to an outside source, water goes everywhere. I would be very interested in a solution.
  • If you are flushing with the fan running, it will cause the water to go everywhere. I found this out the hard way.
    Barb
  • Welcome to the Forums. :)
    Moved from Forum Technical Support
  • What is the pressure at your hookup, or does it do the same thing when you use your pump?
    Bruce
