Ralph Cramden wrote:
Old-Biscuit wrote:
Outside switch ON
SO it is a Suburban Water Heater....outside switch is for electric & inside switch is for propane
120V AC........Black wire
12V DC (propane)...Red wire
Suburban uses a simple wiring scheme for their 'standard' water heaters
120V AC
Individual Circuit Breaker feds AC Hot/Common to junction box on right side of tank looking at WH Tank from inside RV)
From Junction Box to ON/OFF switch (Black Wire)
From On/Off Switch AC Power goes to the set of T-stats (Left side Black Wire=----top t-stat is HI temp with manual Push to Reset)
From Set of T-stats AC Power goes to Element (Black Wire)
Neutral goes from element back to AC Power Panel (White Wire)
Rockwood uses Suburban heaters and always uses two switches, the one on the heater itself and another on the control panel inside marked water heater electric, usually a blue lighted annoying one beside the million candlepower annoying one that says water heater gas. Both the inside electric and the one on the heater need to be on.
Up until last w/e, the heater worked. Don't see how they could have smoked another element, plus the inside breaker didn't trip if they did. As for the using the 2 switches, IDK. She sent me a pic that showed 2 switches on inside control panel. 1 said water heater and the 2nd said tank heater. I was under the assumption that the 2nd switch was tank pad heater, but do not recall them getting a "cold climate" package.
When we had our Cedar Creek, I recall just turning on/off the switch at the tank. On for electric, off then flip switch on inside control panel for gas. Personally, I think they (or in this case she as she was in the RV couple days before hubby came) forgot how to do a couple things with the water heater being one of them. I would think by now (some 6 years later) that she would remember the "how to's".
