Britches
Jul 25, 2015Explorer
thank you all for your info. The power cord is 25ft. plugged into 30amp at rv park
this trailer in 30amp. I cleaned the filters and gently the fins checked the wiring and connections. I turn on the a/c and it takes right off and blows cold air for 15 min. then trips the inside breaker 20amp that is a/c only. I will go test the volts to see if they are 109 or better by the way the main is 30/15 is this adequate
44,056 PostsLatest Activity: May 04, 2014
