ksg5000
Jul 25, 2015Explorer II
Have you tried running the AC on your generator -that may help isolate the problem.
If the unit runs fine on generator then you have an issue with shore power ... source, extension cord etc.
When I have AC issues I start with cleaning the filters and both the Condenser and Evaporator coils. The Evaporator coils are often ignored because they are under a metal cover on the front of the AC unit - you need to get up top and remove the housing and a number of sheet metal screws to get access. Common problem - use Google to get info on how to clean the Evaporator coil. Cleaning all the coils will help reduce electric load on unit.
If issue continues after cleaning .. then look at the capacitors - if they smell or bulge then replace. If your rigs old replace because they are dirt cheap. If problem continues after replacement of capacitors then it maybe your compressor and the cost of replacing that usually warrants replacement of entire AC.
44,056 PostsLatest Activity: May 04, 2014
