enblethen
Jul 25, 2015Nomad
The 30/15 is a split breaker. The 30 is the main and the 15 is a branch circuit.
I would check the neutral(white) wires in the back of the 120 volt distribution panel. A loose connection causes increase in resistance and voltage drop.
Pick up some electrical grease from your local hardware store.
Disconnect from electrical source
Disconnect each of the neutrals one at a time and inspect for dark coloration of the wire.
Apply a liberal amount of the electrical grease(de-oxidation) to the conductors.
Re-connect wire.
Do this to your branch wires and incoming wires that are attached to the breakers.
DO ONE AT A TIME!
Don't forget to disconnect from electrical supply!
Re-connect wire.
DO ONE AT A TIME!
44,056 PostsLatest Activity: May 04, 2014
