ksg5000
Jul 26, 2015Explorer II
Britches wrote:
this afternoon I went through and checked the wires and the breakers it is all good. the electric pedestal in rv park is brand new. So all looks good. A/C now does not turn on it just hums. fan and a/c positions js maybe time for window a/c huh?ust hummm
New pedestal doesn't mean much. Have you tested the pedestal or asked the park to test the pedestal? Have you asked whether any other RV units in the area are experiencing similar problems? On a hot day the park may not have enough power to power everyone's air conditioner and if your on the tail end of the power supply you maybe getting bumped off.
Failure to start up is usually associated with not enough power, bad starting capacitor, or failing compressor. You should also note that when your air conditioner turns off you won't be able to immediately restart it because the head pressure in the compressor will be too high - let it sit for at least 5 minutes.
Have you gotten up top to examine the capacitors? As rigs age it's common for air conditioners to require more power to start up - in my older rig I replaced the original start capacitor with a hard start capacitor which provided the additional power necessary to resolve my start up issue.
Lastly - have you tried turning all the other stuff that uses electricity off when trying to run your AC - converter, fridge, hot water heater etc?
44,056 PostsLatest Activity: May 04, 2014
