afidel
Jan 14, 2017Explorer II
5k BTU is probably too low but they make 8,10,12k BTU window units that run on 110v so if you measure the space it's likely that you can find a higher capacity replacement if you find you need it. I know that was my plan for the other trailer I was looking at (Amerilite 19DS) that came with an 8k which I had read would be insufficient, I had found a 12k that would fit the factory opening and was just a bit deeper so would only protrude a few inches more.
