yankeeslover's avatar
yankeeslover
Roof Question.. should I freak out?
2 year old camper..upstate NY. I took my camper home this past weekend from outside storage... of course its been cold as heck up this way all spring. Friday and Saturday night i worked in the camper while i had the furnace on heating it up(first time since oct any heat in camper).
Yesterday and today were both finally almost 70 degrees up this way. inside of camper is around 45-55 degrees right now..OK. so i was out walking on my roof an hour ago. just checking the dicor like i usually do and i noticed that when i walk by the fantastic fan the roof creaks(not overly concerned as im sure this is just the plywood creaking). but just to check and make sure no leak i decided to take off the speaker inside the camper that is right next to the fan so that i can check around. I started to freak out when i noticed the top of the speaker seemed damp..same with the insulation that was touching the speaker... I instantly figured i have a leak somewhere..
I just took off the other three speakers for sh__ts and giggles and to my surprise noticed that all 4 speakers seemed alittle damp on the top and the insulation touching it was the same. two of the speakers are on the opposite end of the camper.. I now wonder if this could be a simple case of condensation. like is said its finally warm up this way and the sun is baking on the roof while inside the coach it is only around 45-50 degrees... NOONE is in the camper though.. is this possible that this could just be condensation or does this sound like a huge leak in the roof that is effecting the whole roof(I wouldnt think so)... what else can i check to confirm its not a leak? nothing else is out of the ordinary..thanks...
