ItsyRV
Aug 23, 2019Explorer
In addition to the insulating effect, here's another advantage to using a High Solid 100% Silicone roof coating (regardless of manufacture). Should you get a rip, puncture or slice in the roofing materiel, you can make a fully bonded repair by just applying any 100% High Solid Silicone materiel to the damaged area. No need to play with sealing tapes or lap sealant. Just clean and squirt the designated caulking into the damage area; smooth and level with anything flat, and let dry. It will bond into the existing silicon roof to form a seamless repair. Usually only the color difference will give it away.
