2012Coleman wrote:
RoyBell wrote:
Only issue with putting something over the opening is, it blocks airflow then.
So your vent caps are open? I don't get it then. Unless your entire vent is covered by a maxx air cover and the vent is open inside it.
If that is the case, and you want to sleep late then you will have to forgo the airflow , cover the hole with something and turn on the ac.
We leave the roof vents (caps) open at night to let the heat escape. I was saying if we put something solid over/under the screen, it will block the airflow out the vent, which is the whole point of the vent.
I was seeing if there were other options than the $50-$100 air covers. I do like that I can keep the vents open in the rain though. However, I also don't want to spend the money :). I will check out the dark screen. Maybe that will work.
