Double_Haul
Aug 06, 2014Explorer
Do the seal test first before pulling anything. Make sure you know that the windows are the problem and not assume the windows are the problem. Also during the seal test check the storage doors. I had an issue with the seals on mine.
The repair can be easy but time consuming or difficult if you have to remove floor to ceiling cabinets or if the side framing sits on the flooring material. I was lucky that mine did not.
