Pyrate_Dave's avatar
Pyrate_Dave
Rotting floor in our 2008 Jayflight 26BH
My wife and I have discovered the floor is rotting in our 2008 Jayco Jayflight 26BH in the front bedroom below the side windows on either side of the queen bed. The floor is soft right under the windows but still feels solid next to the bed. The floor in the front basement storage is also soft/rotting. I've never seen any signs of water leaks or water in the camper and the roof does not show any abvious signs of damage (I clean and inspect it each spring and fall).
I plan on calling our RV dealer here in CT (where we bought the TT new in February of 2009) to see if this is something they can repair, however I am concerned that a camper that is only 6 years old would have this type of issue.
Has anyone experienced this or had something like this repaired? I have had a sick feeling in the pit of my stomach over this and am worried that we are going to have to junk the camper.
Any advice or assistance is greatly appreciated.
David
  • Sorry about the issues. When you talk to the dealer, see if they can do a seal test. Individuals on the forum indicate they usually run around $100. This will highlight any area that isn't properly sealed.
  • Thank you RedRocket and Gunner for the incouraging words.
    Will take a look and see what I can do this weekend.
  • Feel your pain I battled water damage in my last popup trailer the entire time I owned it. Turned out that it was a bad seem at the bottom of the camper where the fiberglass met the steel framework. Once I got the water to stop intruding the work began I replaced what needed to be and installed wood laminate flooring the camper sold quickly and I was honest about all the issues. If I hadnt wanted to step up to a TT I would still be using that PUP.
  • Pyrate Dave wrote:
    Wishing now that I had covered the camper while it was not being used.
    A cover may not completely protect it. 100% agree with what Barney said about the source of the water coming from the windows. Chances are the water traveled within the walls which is why the storage area is also affected.
    First thing first is you need to seal the water out then work on fixing the damage. As Barney suggested, pull the windows. I'd be willing to bet the seal (window to wall) on those windows is marginal.
  • Thank you DowntheRoad and BarneyS for your quick and informative replies. I've got a couple of friends that are pretty handy; I'll have them take a look and see what they think.
  • Hi David,
    Sorry to hear about the damage to your six year old camper but it is not unusual at all. Sounds like you have a leak in both of the windows on the side of the camper. I would take the windows out, a very easy task, and replace the butyl tape and the caulking around the frame. This is very likely where the water is coming from according to your description of the damage.
    Then I would take up the floor covering and cut out the damaged flooring. Make any wood repairs necessary and fit in a new piece of plywood. This should not be too difficult and will probably fix the problem.
    Good luck.
    Barney
  • Not good and who needs this kind of frustration.
    Even new campers can have floor/ceiling rot if there is a leak. Sure sounds like you have water intrusion that was undiscovered and unchecked...probably through failing window seals.
    Depending on how extensive the rot/floor failure is, it could be a big job and an expensive one. Check with your insurance co.
    To repair this, the affected area will have to be cut out and replaced and the leak will need to be located and stopped..
    Good luck with it.
