rvshrinker wrote:
All of this is way over my head. Take to a shop for inspection? have a 2 week trip coming up.
Where are you located in the PNW?
Most RV dealers can do it, but they might be booked out after your trip starts.- rvshrinkerExplorer IIIAll of this is way over my head. Take to a shop for inspection? have a 2 week trip coming up.
thank you all goducks10 wrote:
His profile says he has an Outdoors RV TT. Shocks are part of a package along with 16" tires.
The shocks are not high quality but still should last more than 10,000 miles.
ORV was using Monroe shocks and is now using KYB Shocks.
Both are quality brands.- goducks10ExplorerHis profile says he has an Outdoors RV TT. Shocks are part of a package along with 16" tires.
The shocks are not high quality but still should last more than 10,000 miles. Best way to check the shocks is to take them off and manually push on them. If they push real easy or even fairly easy then they're shot. You should have a hard time trying to compress them when they're good.
As for the brakes you have to remove the brake drum. Personally I wouldn't worry about the brakes after 10,000 miles. But I would be looking at doing a bearing repack after 2 years and 10,000 miles. Mainly because you don't know how well the factory packed them.
If you have the EZ lube axles and pumped in grease through them you may have blown a bearing seal which would spray grease on the brakes.
Time for a complete tear down and inspection. - Brake inspection requires removing the brake drum,so you might as well repack the bearings while you are in there.
Bearing repack and brake inspection video on my cargo trailer - jdc1Explorer IIPull the trailer wheel off. Remove cotter pin. Remove the large nut. Remove the drum. Look at the brake shoes. The brake material should be 3/8" thick. Any oil around the shock? 10k miles is nothing for a shock, unless you are doing the Baja 500 with your trailer.
44,066 PostsLatest Activity: Apr 16, 2026
