Duane4238's avatar
Duane4238
Rubber Roof cleaning questions
I couldn't get a straight answer from my RV dealer so I thought I'd try here for opinions. I'm going to clean my rubber roof on my 2011 Keystone Springdale 311. I purchased some Camco rubber roof cleaner and conditioner. The directions say to apply it to a small area at a time, and wipe the area and then rinse with clean water. My problem is that I don't have a fresh water supply at my trailer site. Any water I add to my fresh water tank has to be hauled by me, consequently I use it very sparingly. I was wondering, if I use the Camco cleaner and remove as much as I can with damp clothes, would a good rain suffice to wash off what might be remaining on the roof? Is it going to hurt the rubber roof if it doesn't get hosed off after I wash it with the cleaner? The cleaner is supposed to have a conditioner in it. If it's rinsed off immediately after it's applied, what good is it going to do?
ANY and ALL suggestions will be greatly appreciated. I'm a little too old to be up on a ladder doing the roof by myself so fire away.
Duane
  • Ditto on the soap and car brush, then rinse good and let dry or drive to the next spot:B
    My Rubber roof has been cleaned this way several times and NO problems.
    GET A STEADY LADDER!!!!!!
    Chuck
  • Just use soap and water, no special cleaners or conditioners required or needed.
  • 1st figure out what type of rubber roof it is there are a couple of different membranes that are used on these TT's. Mine is the TPO type and the Lit. on it recomends no chemicals other than a mild detergent wash. If you have an EDPM roof there may be a need for further sealing etc. I am not the one to tell you which way you need to go I am just offering a suggestion that you find out what product your Mfg used and then make sure you are using a compatible product.
  • you need lots of water to rinse it if the protectent sets up with the dirt it willbe in it then and you will have streaks on your sides
