DinTulsa's avatar
DinTulsa
Running the fridge for 2 days off level?
I can’t pull the rv Home to cool the fridge due to a neighbors waterline issue. At the storage lot my rv is sitting a full bubble off level, I was going to plug it in today and pick up the rv Friday morning to go camping. Can it is for a day and a half off level with the fridge on?
  • DinTulsa wrote:
    I went ahead and hooked it up and leveled it out. Now I don’t have to worry about it.
    You made a wise decision!
    That is what you should do.
    20 minutes of off-level fridge operation begins causing damage which is accumulative and permanent
  • I went ahead and hooked it up and leveled it out. Now I don’t have to worry about it.
  • Impossible to say. Bubble levels have different sensitivities and you don't say which way it's unlevel.
    The refrigerator should not be more than 3 degrees unlevel left to right, or 6 degrees unlevel front to back.
  • wnjj's avatar
    wnjj
    Explorer II
    If it's within spec (which I believe is 6 degrees front to back of the fridge and 3 degrees side to side), got for it. If not, why can't you level the trailer? Bring blocks for under the tires and a jack if needed.
  • You might, but I would NOT.
    Get some dry ice to boot strap the cooling down process.
