good idea.. most of the new Airstreams are coming from factory with white paint on the area from awning on both sides to behind the nose part.. you really don't see it from the ground..
The folks with older unit that have done this say it help a LOT with heat and noise a bit.
I use a product call KoolSeal on the mobile home i own.. it designed to stick to metal, fiberglass etc adn is quite thick. I bought a 5 gallon container at Sherwin William paint store for a lot less than Lowes, homedepot etc.
GordonThree wrote:
Paint your roof. I learned in another thread in this forum, the shiny aluminum roof KZ uses turns the box into an oven on sunny days. Something called Snow Coat or some such, reported to make a huge difference. Search the forum about painted roofs. I was skeptical, but after study, it sounds plausible.
