the_c_s's avatar
the_c_s
RV Battery Charge
We have a 2015 Zinger TT that was purchased from Camping World about 2-1/2 months ago, and the problem I'm having is the battery won't hold a charge for more than a few hours once it's unplugged from the house.
I had the unit back at Camping world a little over a month ago to take care of a few warranty issues and I asked them to check the battery and charging system while it was in the shop. When I picked the unit up, I was told the battery load test and the charging system both checked out OK. It was a new unit, so I assumed I was leaving something on inside.
I spent this past weekend cleaning and winterizing the unit, so it was plugged in from Saturday morning, until about 10AM today, (Monday). When I unplugged it, It showed a full charge on the inside monitor panel, and I even checked it with my volt meter and got 12.4 volts(after it was unplugged). I got 13.9 volts when it was plugged into the house, so I'm guessing it's being charged. Less than four hours later, the battery is almost dead. There was nothing on or running inside the camper. The voltage reading when I checked the battery was a little over 10 volts.
I called and spoke to one of the service guys at Camping world, and he said that it's normal for the battery to be 100% dead withing 6 - 8 hours after unplugging from shore power. He also said that the battery wasn't covered under my warranty. Keep in mind, I bought this camper NEW at the beginning of September.
Can anyone tell me if what I'm being told is accurate before I call back tomorrow and lose my cool? I have not had pleasant dealings with these people, and if it wasn't for the fact I love the camper, I would have told them to shove it long ago due to other issues to numerous to mention.
** I traded in a 2005 Hornet TT with a 4 year old Walmart battery that would hold it's charge for almost 2 weeks before I would need to plug it in.
Thanks all!
  • the_c's wrote:
    I doubt they ever tested it. I'm taking it to AutoZone tonight and having them test it to be sure.
    Even better, if it tests good have them keep it overnight and test it again in the morning.
    Camping world is feeding you a line.
    13.9 volts sounds a bit low for being on the charger, I would think it should be in the 14's. But even assuming that 13.9 is normal for the charger, you battery is not normal.
    12.4 volts is a battery at only 50% charge. A fully charged battery will read 12.67 - 12.75volts. So your battery is not accepting a full charge. To add more to the case for a bad battery,
    Your 12 volt battery has 6 cells of 2 volts each in series which equals 12 volts. If you are reading 10 volts at all in your battery you have a dead cell.
    I've unfortunately been down this path many times in my frugal life and I can tell you that your battery is dead and needs to be replaced. A battery with a dead cell on the charger may ramp up into the 12v range. But it will drop to the 10 volt range within hours when taken off the charger.
    Here's your easy test. Plug the trailer in and let the battery charge for a few days, heck let it charge until Friday. Then unplug the shore power cable and disconnect the negative cable from the battery so it is isolated from the trailer.
    With a multimeter record the voltage charge at the battery immediately after you disconnect, you should see around 13.9 volts as this is a surface charge.
    After a few hours take another voltage reading, it should be around 12.6x volts. If it's lower you have a suspect battery.
    Let the battery sit disconnected overnight and check it sometime the next day. The voltage should be the same as the few hours check above (12.6x volts) if it is significantly lower 12.5 or lower you have a bad battery. My guess is that within a night or two the battery will drop to 10 volts as it has a dead cell.
    Have Camping world or the dealer charge and test the battery. When they call you up and say it is fine, ask them if they will let it sit off the charger and disconnected and check it again in the morning. I'll bet it reads dead when they do so. Batteries have a warranty and your dealer should be replacing this one, but if they wont you might have to just bite the bullet and spend the $100 to replace it.
  • I doubt they ever tested it. I'm taking it to AutoZone tonight and having them test it to be sure.
  • If you can't find a reason for the battery drain....
    It's possible the battery has gone bad. The newer batteries have thin plates which can break due to road vibration or bad bumps. I had a battery go dead and took it in for testing. The load test showed the battery was good. I charged to full charge and the next day it was dead again. I took it back to the same place for testing and this time it tested bad.
    Is it possible they may have given you an older battery ? One that had been sitting on the shelf for a year or more. Most RV dealers take off the batteries and propane tanks while the RV is for sale on the lot to prevent theft. It might be possible someone grabbed one from the warehouse without paying attention to the condition or date.
  • I agree, the only thing I know for sure that is running is the propane/CO2 detector, but I'm guessing that shouldn't drain the battery that fast.
    Thanks all!
    Clearly there is still a load on that battery. You will need to pull fuses / shut off breakers to find the phantom load. It could be a propane leak detector, radio, amplified antenna, electronic thermostat, fridge, ect. Maybe there is a light turned on inside a storage cabinet??? 6 hours from full to empty is not normal.
