donn0128
May 22, 2018Explorer II
Any of the 2500/250 series of trucks will work just fine. Get a gas motor unless you are towing a LOT. Then a diesel might be a better bargain. While a 1500 might work, you likely would be disappointed with end results. There is jo need to spend 70K for a new one. Either find a gently used or if shopping new, look for lower line trucks. For instance a New Ran Tradesman with a gas motor you should be able to find for well under 50K. Dennis Dillon near Boise,ID usually sells for far lower than other dealers. And they have a fly/drive deals. Turn it into a mini vacation.
