I really hate this stuff, I actually get stressed out when I know I need to work with it. I have tried everything, putting it in hot water, blowtorch, microwave, it is just the pits to work with thi...
Camping World sells two versions. I used the premium or maybe they call it heavy duty. It was very easy to use and very pliable. I did just my rear corners that bend 90 degrees up to the roof. It was no problem making that bend. I noticed some of the stuff I looking at was very hard and not pliable at all. I did not have to use a roller. While changing out the trim I also one at a time removed every screw and filled the hole with pro-flex RV sealant.
