gmw_photos
Oct 08, 2013Explorer
sunovertone wrote:
Hello! I would really like to purchase a r vision 23rbs trail light travel trailer. It has a 23 ft box and 27 ft from bumper to bumper. I have a 2010 nissan crew cab 6 cylinder frontier. It can tow 6100 pounds. I think the pay load is 1116 or so. The wheel base is 126. I know I can tow 24 ft with my wheel base, but, I would like to know if I can tow safely 27 ft. I do not think weight is an issue, the trailer only weighs 4000 dry. I really like my truck and really want this trailer, but just need to know if is ok combo!
The first question you need to ask yourself is, "do I want to stay within manufacturer stated limits, or am I one who believes those limits are just a suggestion" ??
If you are willing to go over the rear axle limit of the truck, then this can probably be rigged to pull ok, if you have reasonable expectations about how fast you can pull, etc. The key will be careful setup of a good weight distributing hitch and sway control and of course a good brake controller.
But....and this is caveat.... you will almost certainly be over the rear axle rating.
I pull a funfinder that is just under 4000 pounds with my '06 Frontier ( V6, crewcab, 6 speed manual ) and it pulls excellent. I also sometimes pull my horse trailer, which is about 4500 loaded, also pulls well. However, with these trailers I am getting very close to the trucks axle limits, so I would not want to pull more weight than these trailers.
Having said that, I was in Colorado a few weeks ago, and had a conversation with a fellow from Denver that was pulling a 5000 pound camper with a Honda Ridgeline, and he claimed it pulled very well, even at high altitude. I would not have guessed it would be a good combo, but maybe ? I'm sure he was over the trucks stated limits though, so take that for what it's worth.
Also, for what it's worth, regarding a Nissan Titan, as much as I like the looks of the truck, and Nissan in general, I probably would not recco one as a tow vehicle for a heavier trailer. There are other options in that class that are likely better suited ( as in, "all the other manufacturers", which would be Ford, Chevy, Ram and Toyota ).
EDIT: I just looked at the trailer website. They are claiming a dry weight of almost 4300, so in the real world, figure it's going to weigh around 5300 ready to camp. That will be a tongue weight of around 690 pounds when set up correctly.
And don't fall for people telling you put weight behind the trailer axles to lighten the tongue weight. Bad idea that can lead to an unstable and unsafe towing experience.
44,066 PostsLatest Activity: Oct 04, 2013
